yannvandenabeel
Aug 30, 2021Follower
Adresde ip sur PLW1000v2
Bonjour , Je n arrive plus à paramétrer mon plw1000v2. Probleme "adresse ip indisponible " Pouvez vous m aider svp Merci.par avance Yann
Aug 30, 2021Guru - Experienced User
Potentially your router assigned a different IP address for it.
Log into your router and check to see its connected and what IP address was assigned to it.
Use that address to access it.
