dpeng1124
Dec 13, 2020Initiate
Advanced-Security-Block Sites feature not working after firmware update V1.2.0.76_1.0.1
Product: Nighthawk AC1750 router I was able to block sites successfully before installing the firmware V1.2.0.76_1.0.1 update. After doing this firmware update and in trying to block websites using...
m4rc077
Jan 12, 2021Aspirant
Did anyone get a resolution on this? I have the same behavior after upgrading firmware V1.2.0.76_1.0.1. See screen shot. It's very frustrating. I tried clearing cache/cookies/etc. Even tried on my secondary PC to no avail.
DarrenM
Jan 27, 2021Sr. NETGEAR Moderator
I will look into this issue,
DarrenM
- miss_kittyJul 21, 2021Aspirant
I'm curious as if there's been any solution to this issue. I'm having the exact same problem after the firmware update. After entering any keyword and hitting "apply," I receive the "403 forbidden" error.
I have recently performed a factory reset, but the issue persists.
Thank you.
- schumakuJul 21, 2021Guru - Experienced User
Unlikely - this keyword filter block does work on http only.
The one we talk about here is that it does not work, well, for the obvious https reason - nothing firmware update related.
There could be several reasons. Unfortunately you have not told us which exact router model (there are at least three vesions of the model listed), which firmware update, and what keyword you have entered.
But seriously, this is a little bit academic - the feature won't become more workable....
Model R6700v2. Firmware Version V1.2.0.76_1.0.1
This was never a problem until recently. I already have some keywords listed that were entered some time ago, but everything I enter now gives the "403 forbidden" error as soon as I apply.
I've tried entering websites and just simple words, but it won't accept anything anymore.
I understand you say it's "unworkable," but it's frustrating since it's only a recent issue with the router.
