dpeng1124
Dec 13, 2020Initiate
Advanced-Security-Block Sites feature not working after firmware update V1.2.0.76_1.0.1
Product: Nighthawk AC1750 router I was able to block sites successfully before installing the firmware V1.2.0.76_1.0.1 update. After doing this firmware update and in trying to block websites using...
GlenW
Dec 23, 2021Aspirant
Since the most recent firmware update the parental controls don't work with OpenDNS nor are we able to block specific sites using the router portal.
I purchased this router specifically for these options. Please this need to be addressed.
schumaku
Dec 23, 2021Guru - Experienced User
Two different issues:
Wild guess: You configured the OpenDNS IPs on the router, but the DHCP server does issue the ISP-assigned DNS IPs instead?
Keyword blocking can only work on plain http sites - something rare these days.
