33Tomo
Oct 23, 2019Initiate
Advanced settings do not show USB Storage on c7100v
I have just purchased a C7100V Modem Router combination. My WD My Book 1tb drive worked on my wndr3400v2 and I want to use it on the new router. Reading the user guide, it tells me to go to Advanced,...
- Oct 24, 2019
Thank you for your help.
I called support and they told me that it might be a hardware problem with the router. A new router fixed the problem.
michaelkenward
Oct 24, 2019Guru - Experienced User
The C7100V is a Cable Modem Voice Router. You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice there related to your hardware.
I have asked the Netgear moderator to move your message.
