MPotamia
Dec 13, 2020Tutor
After firmware update refuses local browser connect for admin ("192.168.x.1 refused connection")
I have been logging in to administer this router for several years from the local network. Sometimes via local LAN sometimes via WLAN, sometimes via remote into a server I remote into. (Never allowed...
- Dec 14, 2020
MPotamia wrote:I have been logging in to administer <<snip>> And how do I fix?
I found someone to go in an power reboot the R6300v2. It now gives login prompt, and all
And firmware on router shows V1.0.4.46_10.0.93, not what I said earlier (I couldn't login to see what it said). Also I thought things were working before reboot just not giving login to browser, but i was wrong, DNS was hosed I didn't realize it.
This is the first time an update didn't go right, and required a manual reboot.
Out here / MP
antinode
Dec 13, 2020Guru
> [...] Allowed it to update itself [...] and suddenly now it refuses
> connection.
Perhaps the firmware update failed. Did you try any extreme
diagnostic procedures, like, say, looking at the LED indicators on the
router?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot".
> [...] change in 1.0.4.36 that's preventing a browser on my server on
> my home network from connecting to the 192.168.2.1 ?
Unlikely. The default LAN IP address is "192.168.1.1". You changed
yours? If the firmware update somehow triggered a settings reset, then
that setting could have been lost.
> [...] And how do I fix?
First, I'd visit the router, and examine it. Then, if its LEDs
looked good, I'd connect a computer to it and see what more
troubleshooting might reveal.
- MPotamiaDec 13, 2020Tutor
The router is 4800 miles away across a big body of water. That's why I teamviewer into that network thru a server. And like I said, everything is working as far as I can tell -- i can ssh into my devices, teamviewer into my server, hit my cameras, etc etc. Only one thing: from my server's chrome, firefox or ie, cannot bring up the login page of the router. Yes I set up my home network as 192.168.2.1 and can ping it from any device on my network. Thanks for the great extreme troubleshooting thoughts.
