StoneSword
Jan 23, 2021Aspirant
After Firmware update V1.2.0.66 wifi speeds are slow
I just recently updated the firmware on my WNR3500Lv2 router to the current version: V1.2.0.66 and noticed that my wifi speeds are slow. For example, watching YouTube videos on my phone while con...
Jan 29, 2021Guru - Experienced User
the gateway is the device the router connects to for internet service.
Firmware will be in the top left corner or the advanced status page if you log in through the browser.
speeds over 2.4ghz you use a 2.4ghz laptop/pc/phone and speedtest it .
StoneSword
Jan 30, 2021Aspirant
plemans wrote:the gateway is the device the router connects to for internet service.
I don't understand about the gateway. Are you talking about an actual device or an IP address?
WNR3500LV2 current firmware I have is V1.2.0.66.
When sitting in my office where I have my modem and router, testing the signal strength is 100% signal, 144Mbps.
- michaelkenwardJan 30, 2021Guru - Experienced User
StoneSword wrote:When sitting in my office where I have my modem and router, testing the signal strength is 100% signal, 144Mbps.
This "modem" may also be a "gateway". A gateway usually refers to a modem/router that has added features, such as a telephone socket.
Tell people the make and model of this modem and you may get better help.
Any speeds you test over wifi are more likely to measure the capability of your wifi devices, not your Internet speed. The only reliable tests are with a direct wired connection.
- plemansJan 30, 2021Guru - Experienced User
link speed isn't the same as actual throughput speed. And 2.4ghz is slow.
so what actual speed do you get out of it?
- StoneSwordJan 30, 2021Aspirant
plemans wrote:link speed isn't the same as actual throughput speed. And 2.4ghz is slow.
Ah ok, thank you for clarifying that. I haven't really been keeping up with the current technology for the past 4 or 5 years.
My modem is a Netgear CMD31T and I tested my internet speed my result was 137.5Mbps
My router is a Netgear WNR3500Lv2. I'll keep posting my router that way there isn't so much back tracking to see what router I have.
- plemansJan 31, 2021Guru - Experienced User
so the router is getting the full 137mbps hardwired in?
And what speeds do you get over wireless? Just trying to see if you're speeds are actually slow or an expectation of that router
