StoneSword
Jan 23, 2021Aspirant
After Firmware update V1.2.0.66 wifi speeds are slow
I just recently updated the firmware on my WNR3500Lv2 router to the current version: V1.2.0.66 and noticed that my wifi speeds are slow. For example, watching YouTube videos on my phone while con...
StoneSword
Jan 30, 2021Aspirant
plemans wrote:the gateway is the device the router connects to for internet service.
Firmware will be in the top left corner or the advanced status page if you log in through the browser.
speeds over 2.4ghz you use a 2.4ghz laptop/pc/phone and speedtest it .
I don't understand about the gateway. Are you talking about an actual device or an IP address?
WNR3500LV2 current firmware I have is V1.2.0.66.
When sitting in my office where I have my modem and router, testing the signal strength is 100% signal, 144Mbps.
michaelkenward
Jan 30, 2021Guru - Experienced User
This "modem" may also be a "gateway". A gateway usually refers to a modem/router that has added features, such as a telephone socket.
Tell people the make and model of this modem and you may get better help.
Any speeds you test over wifi are more likely to measure the capability of your wifi devices, not your Internet speed. The only reliable tests are with a direct wired connection.
