StoneSword
Jan 23, 2021Aspirant
After Firmware update V1.2.0.66 wifi speeds are slow
I just recently updated the firmware on my WNR3500Lv2 router to the current version: V1.2.0.66 and noticed that my wifi speeds are slow. For example, watching YouTube videos on my phone while con...
michaelkenward
Jan 31, 2021Guru - Experienced User
StoneSword wrote:
My modem is a Netgear CMD31T and I tested my internet speed my result was 137.5Mbps
Cripes. That's seriously old. 2013.
According to the specifications, it is DOCSIS 3.0 standard. Newer devices are 3.1, but there's no point in having that unless your ISP demands, and supports, it.
At least it has a Gigabit Ethernet port. Not all devices of that generation are that fast.
Still, it does rule out the dreaded "double NAT" affliction. Plain modem. No router.
Sadly, the WNR3500Lv2 is also old. 2011. No 5 GHz wifi. (Again, though, it does have Gigabit Ethernet.) But you should get better speeds than you see.
If your trouble started after you applied the latest firmware, you could always install on older version.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
StoneSword
Jan 31, 2021Aspirant
michaelkenward wrote:
StoneSword wrote:My modem is a Netgear CMD31T and I tested my internet speed my result was 137.5Mbps
I figured if it was time to get a new modem and router. But my internet was fine until I updated my router to the current firmware. Then my wifi went to complete crap.
I think if I install the older firmware I should be okay.
- michaelkenwardJan 31, 2021Guru - Experienced User
No guarantees there! But nothing lost either.
