tjrub
Oct 21, 2021Follower
After hard reset now getting weak security notice on my Ipad
I recently had to perform a hard reset on my C6300 modem/router. Was able to reconnect all devices but my Ipad has a "weak security" message saying WPA/WPA2 (TKIP) is not considered secure. I need to...
JWS9518
Oct 21, 2021Luminary
I am not familiar with that model, but if it has WPA3 capability, you will need to login to your routers setup and check the wireless settings. You can change your security settings there.
Keep in mind that some devices may not like or be compatible with WPA3.
