tjrub
Oct 21, 2021Follower
After hard reset now getting weak security notice on my Ipad
I recently had to perform a hard reset on my C6300 modem/router. Was able to reconnect all devices but my Ipad has a "weak security" message saying WPA/WPA2 (TKIP) is not considered secure. I need to...
Oct 22, 2021Guru - Experienced User
The C6300 doesn't have wpa3 capability.
So you'll have to use wpa2. Kitsap has went over how to get the manual to access wireless settings.
- schumakuOct 22, 2021Guru - Experienced User
The "weakness" Apple complains about comes from the WPA TKIP mode. Like many Netgear devices, it's not possible to disable WPA TKIP on it's own.
PS. Yes FURRYe38 we know there is a better community, but it does not make ANY sense to cause yet another duplicate thread. Netgear mods will (hopefully) move this thread accordingly, too.
- FURRYe38Oct 22, 2021Guru - Experienced User
Just FYI for the OP.
Thanks.
