tjrub
Oct 21, 2021Follower
After hard reset now getting weak security notice on my Ipad
I recently had to perform a hard reset on my C6300 modem/router. Was able to reconnect all devices but my Ipad has a "weak security" message saying WPA/WPA2 (TKIP) is not considered secure. I need to...
Oct 22, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you
tjrub wrote:
I recently had to perform a hard reset on my C6300 modem/router. Was able to reconnect all devices but my Ipad has a "weak security" message saying WPA/WPA2 (TKIP) is not considered secure. I need to use WPA2 (AES) or WPA3. How do I do that?
