miketagg54
Jan 31, 2022Tutor
After installing new Nighthawk WiFi Router(R6900P) speed dropped to 10/100 mb out of switch from 1 G
After replacing and installing the new router I noticed that my speed dropped significantly on my eithernet coming from the new router. I njormally have close to a gig of download and upload speed s...
- Jan 31, 2022
Would be yoru switch. If it's not connecting or supporting of 1000Mpbs, then you'll never see anything over 100Mpbs wired.
What brand and model is this switch?
Be sure your LAN cables are of good quality as well. CAT6 is recommended.
miketagg54
Jan 31, 2022Tutor
It is a TP-Link TL-SG108 | 8 Port Gigabit Unmanaged Ethernet Network Switch. It worked fine with my old router and all the outputs from the switch were well over the 100 MB that is coming out now. I also have another small 4 port TP-Link switch and the outputs from that swit56ch are all acceptable. I verified all my cables were tested and all do not seem to have an issue. So agree it must be the switch has gone bad since it is unmanaged without any settings to adjust or test. Thanks for your input.
Jan 31, 2022Guru - Experienced User
I recommend NG GS-105/108v4 and GS308v3.
Good Luck.
