OBoy
Mar 26, 2022Tutor
After power interruptions settings are lost
If I power down router to clear an issue the router does not retain original settings and I have to completely reset everything.
Mar 26, 2022Guru - Experienced User
what router do you have?
What firmware is on it?
OBoy
Mar 26, 2022Tutor
v1.0.11.126_10.2.112
R7000AC1900
- OBoyMar 26, 2022Tutor
I clicked upgrade but it said I had latest copy.
I know 134 is the last one.
If I power down the router everytime I have to go back and load wifi info , port forward and everything else.
Thanks
- plemansMar 26, 2022Guru - Experienced User
the built in update service rarely updates the r7000 properly.
you can manually update it.
https://www.netgear.com/support/product/r7000.aspx
- OBoyApr 03, 2022Tutor
I did the firmware upgrade but did not fix issue.
Is it normal to loose all settings on the router if you loose power ?
Mine does.
