MWh1ttaker
May 14, 2024Follower
After power outage, I have been unable to setup IP cameras (Arlo Q) or Ring Chime on AC5000 router.
I have an X8 R8300 (AC5000) that has performed flawlessly however we had a recent power outage and I have tried on mutiple attempts on laptop and/or associated apps connected to the 2.4 band to recon...
michaelkenward
May 14, 2024Guru - Experienced User
MWh1ttaker wrote:
I have an X8 R8300 (AC5000) that has performed flawlessly however we had a recent power outage and I have tried on mutiple attempts on laptop and/or associated apps connected to the 2.4 band to reconnect my Arlo Q and Ring Chime with no success (states that the device(s) cannot be found).
The first, and simplest, move after power cuts is to ensure that the network starts in the right order.
Power cuts usually take out both the modem and the router on a network. When the power comes back on, things may start in the wrong order, with the router starting before the modem is ready, for example. That means that they get confused about which is in charge.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Only then look into the more severe suggestion from plemans and microchip8.
It might also help if you said what modem/gateway/ONT sits between the R8300 and the Internet.
