JADE2021
Oct 08, 2021Follower
After subscribing. How to reconnect the router?
Oct 09, 2021Guru - Experienced User
What router?
What did you subscribe to?
what is actually going on?
You gave us next to nothing to go offf. Details are key since we aren't there.
Go to netgear.com/support/ type in your actual model number.
It'll take you to guides, firmware, manuals. These are great in helping as well.
- michaelkenwardOct 09, 2021Guru - Experienced User
Oh so true.
Start here:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
There may also be some helpful videos on what to do.
