knodi
Sep 24, 2017Guide
After updating R7800 to firmware 1.0.2.36 Time Machine can't see network drive
After updating R7800 to firmware 1.0.2.36 Time Machine can't see network drive. I can' connect to the drive but it won't show up under Time Machine drive select. It was working fine in the previous v...
- Sep 26, 2017
Updating the firmware to Voxel's custome firmware fixed the issue.
William10a
Sep 25, 2017Master
knodi wrote:After updating R7800 to firmware 1.0.2.36 Time Machine can't see network drive. I can' connect to the drive but it won't show up under Time Machine drive select. It was working fine in the previous versions. I see in the release notes that 1.0.2.36 has a SMBv3 update.
Can anyone else confirm this issue?
Yes SMBv1 was replaced if Time Machine app can not support version 3 of smb that may be the problem I would try the reset of the router since changes may have been made to other parts of the new firmware. Would not be the first time that a upgrade in security on a program causes issues with other older programs that have not been patched with a need update.
