knodi
Sep 24, 2017Guide
After updating R7800 to firmware 1.0.2.36 Time Machine can't see network drive
After updating R7800 to firmware 1.0.2.36 Time Machine can't see network drive. I can' connect to the drive but it won't show up under Time Machine drive select. It was working fine in the previous v...
- Sep 26, 2017
Updating the firmware to Voxel's custome firmware fixed the issue.
perseid
Sep 25, 2017Aspirant
The download link for the latest firmware is still broken (file not found), how did you download it?
- michaelkenwardSep 25, 2017Guru - Experienced User
It is usually better to stick with just one conversation, especially as this one is about a completely different subject:
Unable to download latest firmware/"File not found... - NETGEAR Communities
- knodiSep 25, 2017Guide
Firmware Update under the Administor setting on your router's webadmin portal. There is a "check" for firmware update. It finds it from there.
