jacoboramos1
Jul 11, 2020Aspirant
After Upgrade R8000 X6 died
After upgrade R8000 X6 died, what happened: 1.- Tried to upgrade last night X6 to the lastest firmware 2.- Router lost WiFi / Internet 3.- DHCP also died, if I use an static IP 192.168.1.x I an p...
- Jul 11, 2020Downloaded the latest firmware, Did tftp 192.168.1.1 activated verbose mode / bin / put new firmware file takes around 40 seconds. To transfer the file. Be patient after a couple of minutes the router rebooted and voila. Unfortunately I called support and activated a one year contract before being able to read the post :-)
antinode
Jul 11, 2020Guru
> [...] power light is blinking [...]
You may be a candidate for the TFTP recovery scheme. See, for
example:
- jacoboramos1Jul 11, 2020AspirantDownloaded the latest firmware, Did tftp 192.168.1.1 activated verbose mode / bin / put new firmware file takes around 40 seconds. To transfer the file. Be patient after a couple of minutes the router rebooted and voila. Unfortunately I called support and activated a one year contract before being able to read the post :-)
