mover0
Jun 22, 2022Aspirant
After upgrade to 1.0.2.90 R7800 (X4S) does not open an http port.
Logged into the R7800. The GUI informed me that a firmware update was available. Using GUI downloaded and upgraded firmware from 1.0.2.62 to 1.0.2.90. Routing and WiFi are working, and the router ...
- Jun 23, 2022
Do NOT user the TFTP method to upgrade the router. This is only for last resort.
First try the factory reset with the router and setup from scratch with a good browser and wired PC at 192.168.1.1.
michaelkenward
Jun 23, 2022Guru - Experienced User
mover0 wrote:
As a result, http connections to the router
GUI are refused. Internet service is not affected.
What is the most direct way of restoring access to the GUI?
GUI works fine here.
Tried a reset?
mover0
Jun 23, 2022Aspirant
Sorry, neglected to say neither reset nor power cycle improved matters.
