gmonkeyq
Feb 18, 2018Aspirant
Already registered
My product says it was already registered. Why can't I re-register it in my name, I bought it from a guy on LetGo, if they're allowed to sell them then i should be allowed to reregister it.
- Feb 18, 2018
Of course. http to the address listed on the bottom of the router and use the username/password listed there.
If you can't get in, do a factory reset (tiny button hole on bottom/back of router) and that will/should reset things to what is listed on the label on the bottom of the router.
duckware
Feb 18, 2018Prodigy
If it was sold as "new" -- return it, it is not new. If it was sold as used, you can't register it.
- gmonkeyqFeb 18, 2018Aspirant
Without it being registered can I still change its name and password? If so, how?
He said it was new and unopened, but it still works very good, but Can I change the name of the network and the password without it being registered?
- duckwareFeb 18, 2018Prodigy
- michaelkenwardFeb 19, 2018Guru - Experienced User
Spot on there, and to deal with "already registered" issue – that's the third today – you probably need divine intervention, or at least help from one of the Netgear support people.
Here's how it worked in the past:
Solved: Cant register product (AC1200-R6220) WiFi router) - NETGEAR Communities
Hope it works.
