gmonkeyq's avatar
gmonkeyq
Already registered
My product says it was already registered. Why can't I re-register it in my name, I bought it from a guy on LetGo, if they're allowed to sell them then i should be allowed to reregister it.
  • duckware's avatar
    duckware
    Feb 18, 2018
    Of course.  http to the address listed on the bottom of the router and use the username/password listed there.
    If you can't get in, do a factory reset (tiny button hole on bottom/back of router) and that will/should reset things to what is listed on the label on the bottom of the router.
