hquant
Aug 20, 2019Tutor
Alternative Port for DDNS
I want to access my Synology NAS and my Router interface sperately from each other. But the DDNS always pushes me to Port 1080. So I always get the NAS, never the router. What port is the router on. ...
- Aug 20, 2019
> ### WAN access via browser.
Ok. Using what, exactly, as a URL? Note that Remote Management
(Fernsteuerung) uses "https://".If, from here, I try the URL on your Fernsteuerung page, _I_ get to
your router (after Firefox complains about the certificate):https://xxxxxxxx.mynetgear.com:8080 is requesting your username
and password. The site says: "NETGEAR R7000P"(And then, when I fail to put in the right user+pass, it starts trying
to "help" me with a "Router-Passwort wiederhergestellt" page. I don't
know your serial number, either.)"http://xxxxxxxx.mynetgear.com:1080" takes me to a "Heikos
Homeserver" page (for which I also have no valid credentials). I assume
that that's your NAS.
So, I see no obvious problem. Are you trying to access your
Fernsteuerung URL from the outside world, or from a system on your LAN?
Around here (D7000[v1], V1.0.1.74_1.0.1), I fail to reach my own Remote
Management site (Firefox: "The connection has timed out") from a system
on my LAN. I might call that a firmware bug.Interestingly, in general, NAT loopback works for me. I can get to
my own web server using "http[s]://<my_public_IP_address" from my LAN,
but not to the D7000 Remote Management site, using the recommended URL
(same address, different port). (I don't know if I've ever tried to use
Remote Management from some remote location, so I can't say with
certainty that that works. But I assume so.)
hquant
Aug 20, 2019Tutor
Remote Management Settings
antinode
Aug 20, 2019Guru
- hquantAug 20, 2019Tutor
Thanks for your help. You should probably work in IT forensics, since you made it all the way to the login screen of my NAS
and my router. Actually HTTPS did the trick. I tried it yesterday without success based on you recommendation but I may
have misspelled the URL. I will try it from within my network tonight as well. But from my company PC everythings works
nicely. That was the main point. So thanks again!! You've been a great help to thick me.
