molaver
Nov 20, 2021Tutor
Amazon Device on Nighthawk?
On my Nightwawk App device manager I am seeing a device called AMAZON-OA2BO8803. We have no Amazon device (that I know of). Does anyone know what this device is? I have disabled wifi to it which h...
- Nov 21, 2021
Using the link that you provided, the manufacturer is Amazon Technologies. And, I just realized what the device is ....an Alexa/Echo Dot. I now feel like an idiot. Thank you all for your replies and help with this.
molaver
Nov 21, 2021Tutor
Thank you for your reply. I don't know how to find a Mac address as you suggested and I mentioned the router because I thought it might be helpful in some way. To clarify, my router is an older AC1200 Model R6220.
michaelkenward
Nov 21, 2021Guru - Experienced User
For questions about that router, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
General WiFi Routers (Non-Nighthawk & Non-Orbi) - NETGEAR Communities
But your query doesn't really depend on the hardware. I was just confused by the reference to a USB adapter. A very different animal.
