kgeoffrey
Sep 07, 2021Guide
Amber Ethernet LED on Modem
Howdy, I have a Nighthawk R7000 router and CM400 modem. From what I have read here, the amber ethernet LED indicates my connection is 10/100, but the R7000 is supposed to handle 1 Gigabit. Al...
- Sep 07, 2021
have you tried swapping in a new ethernet cable? I've seen sketchy cat 5e only connect at 10/100mbps.
michaelkenward
Sep 08, 2021Guru - Experienced User
kgeoffrey wrote:
Howdy,
Which LED are you talking about? The LAN LEDs indicate the speed of devices plugged into the LAN ports. They are not related to the link between the router and the modem.
- kgeoffreySep 08, 2021Guide
Thanks michaelkenward I'm talking about the ethernet LED on the CM400. Mine is not green. It is amber.
- plemansSep 08, 2021Guru - Experienced User
did you try a different cable?
If you direct connect a pc/laptop to the modem, does it connect at gigabit speeds?
- michaelkenwardSep 08, 2021Guru - Experienced User
Go it. I couldn't see that from your first message.
