creator439
Jul 22, 2021Follower
Amber LAN LED on R7000, have network...
Hi all! I've just replaced my old R7000 with a new one (bad storm came, and whipped its A$$). So with my old one, when I had my PC connected to the router, the LAN was amber, but the network ...
Jul 22, 2021Guru - Experienced User
If you swap ports on the router that the computer is connected, does the port you change it to, also change to amber?
Could be a bad lan port on the computer.
Could be a bad cable.
