draftdoug
May 18, 2018Follower
amber light when I plug in t-mbile line link
Just wondering why the port where I have my t-mobile line link (voip phone) plugged in is amber. The phone works but i am wondering if the quality is the best. All other lights are white. I have trie...
- May 18, 2018
It is probably a 100 mb connection (amber) not a 1 gb connection (white).
antinode
May 18, 2018Guru
> phone) plugged in is amber. [...]
As a description, "my t-mobile line link (voip phone)" is much less
useful than a model number would be.
> [...] My firmware in up to date. [...]
An actual version number would be more useful than your opinion of
what's "up to date" today.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "LED and button
descriptions".
The LED color indicates the speed: white for Gigabit Ethernet
connections and amber for 100 Mbps or 10 Mbps Ethernet
connections.
(Further reading might not hurt much, either.)
Without an actual model number for your "my t-mobile line link (voip
phone)", it's hard to say what to expect for a link speed, but I doubt
that VOIP needs gigabit speeds for proper operation.
- William10aMay 18, 2018Master
