draftdoug
May 18, 2018Follower
amber light when I plug in t-mbile line link
Just wondering why the port where I have my t-mobile line link (voip phone) plugged in is amber. The phone works but i am wondering if the quality is the best. All other lights are white. I have trie...
- May 18, 2018
It is probably a 100 mb connection (amber) not a 1 gb connection (white).
michaelkenward
May 19, 2018Guru - Experienced User
What is that port? LAN?
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
See page 12.
