Ajjr32
Mar 08, 2021Follower
Amber light
Solid white light becomes solid amber on my router when desktop computer enters sleep mode. Replaced Ethernet cable, no change.
1 Reply
> [...] Solid white light becomes solid amber on my router [...]
How many lights are there on your "my router"? _Which_ "Solid white
light becomes solid amber on [your] router?Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions. Now that we know what "amber" means, ...> [...] when desktop computer enters sleep mode. [...]
On some computers/devices (such as your (unspecified) "desktop
computer", apparently), an Ethernet interface will run at 100MHz when
the device is in a standby or (not-truly) "off" mode. When such a
device is awakened or powered on, it may negotiate a faster link rate.If the computer's sleeping, then how important to you is the speed of
its Ethernet interface?> [...] Replaced Ethernet cable, [...]
If the cable was good when the computer was powered on, then I'd bet
that it stayed good when the computer was shut down.Don't worry; be happy?
