bosoxguy17
Jan 27, 2017Aspirant
amber lights on top of nighthawk 6700
I have my amazon fire tv box and PS4 connected to my router via ethernet cable. when i use my ps4 the amber light turns white but when i use my amazon box it stays amber why is this? i feel like the ...
- Jan 30, 2017
Hi bosoxguy17,
The LAN ports of the router is gigabit. If the device connected to it is gigabit as well then the light is white. If the device connected is upto 100Mbps only then the light is amber.
bosoxguy17
the top of the router is where the lights are
- StephenBJan 27, 2017Guru - Experienced User
Your Amazon FireTV has a fast ethernet connection (100 mbits), and your PS4 has a gigabit connection (1000 mbits).
The router shows fast ethernet with amber, and gigabit with white. So there is nothing wrong with the router (or the two devices).
- michaelkenwardJan 27, 2017Guru - Experienced User
the top of the router is where the lights areI know where the lights are. I really wanted to know which of the dozen or so lights changes colour.
StephenB has given you the same answer that I gave.
Does that answer your question?
Or is it a different light that changes colour? Not the LAN indicator.
The manual is here:
R6700 | Product | Support | NETGEAR
Page 11 refers to the LAN lights.
