bosoxguy17's avatar
bosoxguy17
amber lights on top of nighthawk 6700
I have my amazon fire tv box and PS4 connected to my router via ethernet cable. when i use my ps4 the amber light turns white but when i use my amazon box it stays amber why is this? i feel like the ...
  • JamesGL's avatar
    JamesGL
    Jan 30, 2017
    Hi bosoxguy17,
    The LAN ports of the router is gigabit. If the device connected to it is gigabit as well then the light is white. If the device connected is upto 100Mbps only then the light is amber.
