gkski's avatar
gkski
Amber Power Light Redux
My AC1750 router has been running flawlessly since summer but is again exhibiting the amber power light and network disruptions.   I received some helpful advice before and have an outstanding ques...
  • michaelkenward's avatar
    Jan 21, 2022
    gkski wrote:
    What I should have said is that many of the lights were on the router, amber and white, some flashing when I went up to my office to see what was wrong with network connectivity. I have the router configured to only light the power light.
    "Flashing" firmware is usually used to describe using a process like TFTP to mend a device with corrupt firmware.
    The only light that matters when it comes to "flashing" the firmware is the power LED. If that is orange, then you may need to do something. If that LED remains white, then you should not think about flashing the firmware.You don't need it and can do more harm that good.
    You can simply use the routing update process.
    As to all the other lights, if you reset the thing at any stage, the lights will get back to their default state and will come back on.
    Otten the router log shows lots of DoS ACK and FIN attacks, but I think I read those could be misinterpreted.
    You are not wrong there. Many of those reports are false alarms. But if they flood your router, that could strain the processor and bring it to its knees. That is one reason why people turn off logging those events. Disabling other processor heavy activities, like QoS and traffic metering, is another tactic. The R6400, from 2015, isn't a powerful router by modern standards and may be feeling its age.
