mparsel
Oct 31, 2020Tutor
Android OVPN Configuration File for Firestick 4K
Is there a single OVPN cliebt configuration file for the firestick?
- Oct 31, 2020
Problem solved. all you need to do is identify the file location in the client3 file. (e.g. ca /download/openvpn/ca.crt, cert download/openvpn/cliernty.crt, ...)
mparsel
Oct 31, 2020Tutor
I would like to include the CA, Cert and Key in a single configuration file. The firestick wont read the seperate files when running client3.ovpn.
- mparselOct 31, 2020Tutor
