mparsel's avatar
mparsel
Tutor
Oct 31, 2020
Android OVPN Configuration File for Firestick 4K
Is there a single OVPN cliebt configuration file for the firestick?
  • mparsel's avatar
    mparsel
    Oct 31, 2020
    Problem solved.  all you need to do is identify the file location in the client3 file.  (e.g. ca /download/openvpn/ca.crt, cert download/openvpn/cliernty.crt, ...)
