dmbsig
Dec 28, 2020Tutor
Anker Nebula Capsule Max unable to connect to Netgear NighthawkX6S AC3000
For Christmas, I received a wifi projector (Anker Nebula Capsule Max). This projector supposedly has the ability to connect to your wifi, and be able to play Netflix, Amazon movies, etc however, I c...
Dec 29, 2020Guru - Experienced User
What modem/gateway do you have?
What firmware is on the router?
What actual router do you have? AC3000 is a s peed, not a model.
- dmbsigDec 29, 2020Tutor
My Mistake!
What modem/gateway do you have? ZHONE ? What info from the modem do you need?
What firmware is on the router? V1.4.1.66_1.3.26
What actual router do you have? AC3000 is a s peed, not a model. : R7900PAs you may have gathered, I'm a bit of an idiot when it comes to this, making this a much bigger problem than it should be, lol. I appreciate your efforts to help me get this working!
- plemansDec 29, 2020Guru - Experienced User
zhone? Do you have a model number of it?
Reason I'm asking is some devices have issues when you're running a double nat. that's 2 routers in router mode on a network.
https://kb.netgear.com/30186/What-is-Double-NAT
Many ISP supplied modem/gateways have an integrated router.
So just trying to establish if that could be the issue.
On the bottom of the unit it shows
Model: ZNID-GPON-2424A-NA REV: N1
GPON ONT. INDOOR.l 2 POTS
