Khisahar
May 05, 2021Initiate
Any idea if the charger can be switched to a smaller one?
Hello dear community, I just bought the switch GS308 which works perfectly but I have an issue with the charger. I live in a house and use this switch to provide the whole house with wired internet...
antinode
May 05, 2021Guru
> Unfortunately, the charger (by its design) once plugged doesn't allow to
> close the door of the box.
- KhisaharMay 05, 2021Initiate
That is stupidly simple and it's not dumb if it works.
I'll order that from Amazon and wait to see if anyone has another solution.If not, I'll have your post as the solution.
This solution really tests my cable management.
- plemansMay 05, 2021Guru - Experienced User
Hope it works well for you!
