Khisahar
May 05, 2021Initiate
Any idea if the charger can be switched to a smaller one?
Hello dear community, I just bought the switch GS308 which works perfectly but I have an issue with the charger. I live in a house and use this switch to provide the whole house with wired internet...
May 05, 2021Guru - Experienced User
They make cheap 6-12 inch power cord extensions that'd allow you to not have to get a new power supply.
Or even a rotating power plug adapter.
I'd go with one of those 2 routers.
You can always use a different adapter but you need to make sure the voltage and polarity are the exact same. it can have higher amperage but not lower.
