Khisahar
May 05, 2021Initiate
Any idea if the charger can be switched to a smaller one?
Hello dear community, I just bought the switch GS308 which works perfectly but I have an issue with the charger. I live in a house and use this switch to provide the whole house with wired internet...
wellersl
May 05, 2021Aspirant
Any power supply (charger) will work as long as:
1. The electrical characteristics match those on the label of your OEM unit. And,
2. The output plug matches the one on your OEM unit.
