Bill-D
May 16, 2021Apprentice
Any R7000 owners roll the dice on 1.0.11.122 ?
I'm very pleased that the R7000s in both of my houses running on '116 have been outstandingly stable for the last 3 months. I just saw this new '122 hotfix and, always eager to stay ahead of vuln...
May 16, 2021Guru - Experienced User
I don't have one but I'm on the forums regularly. I haven't seen much feedback so far.
If you were going to try it, make a backup of your current configuration, the do the install/reset/clean install process.
If it struggles, you can always downgrade and restore your current configuration
- Bill-DMay 24, 2021Apprentice
Since I haven't seen any negative experencies reported about '122, I rolled the dice and updated from '116 without an erase/reset. Hopefully, the stability I've experenced with '116 will continue with '122. I'll report back here after running it for a while.
- javierHDMay 26, 2021Aspirant
I have been having problems for sometime now and Bill-D provided some advise (thanks for that ). Currently on version V1.0.11.122_10.2.100 still having same issues, dropping internet, poor or inconsistent speedes wired or not. Not sure this has to do with the FW but by the sounds of it I see some similarities.
- DoctorXMay 27, 2021Guide
Another update today. Anyone brave enough to try v1.0.11.123_10.2.100?
