Izzylagging
Oct 13, 2015Follower
Any thing I can tweak??
Xbox 360 (newest version) R7000 Fiber Optic 1gb down / 1 gb up (on Speedtest.net I average about 700 up/down with a 8 ms ping from a server 237 miles away) Xbox is hard wired into router and I hav...
- Oct 13, 2015
The round trip time at the speed of light over 237 miles is about 2.5 ms, so an 8 ms ping time is pretty good. Make sure your modem is set to bridge (or IP Passthrough mode if you have AT&T Gigapower). Don't use QoS, Access Control, keyword blocking or anything that requires the router to perform any kind of extra packet processing beyond basic NAT. Like you said, COD Lag Compensation is going to penalize you, anyway.
TheEther
Oct 13, 2015Guru
