mmeggs's avatar
mmeggs
Any thoughts on a dramatic decrease in speed shortly after implementing USB tethering on an R7000?
The situation - I'm trying to get rid of AT&T DSL and replace it with USB tethering or a hotspot.
Router - R7000 with the latest DD-WRT installed
Internet source - Goggle Pixel 3a with a Visible unlimited data plan
Test network - the R7000 with the Pixel connected by a USB cable and a laptop connected with  an ethernet cable.
After some Googling and fiddling around, I arrived at the eureka moment.  The laptop had internet access, and about 4 times faster than my DSL.  I let the test network run for about 3 hours, including an hour of music videos.  With that success, I decided to disconnect the Linksys (DSL connection) from my network and connect the R7000.
For a few minutes it worked well.  I decided to install a WINE upgrade to the laptop (now WFi connected).  After a few minutes the speed dropped abruptly, and dramatically - well below DSL speed.  And not just WiFi, my desktop with a wired connection experienced it too.  Eventually, the download timed out.  I switched back to DSL, and it was all back to normal.
Any ideas about the cause and fix for the speed drop would be appreciated!  The R7000 did feel a bit warm.
1 Reply
  • plemans's avatar
    You'd be better off to check on the ddwrt forum if thats what you have installed.
    DDWRT is an aftermarket 3rd party firmware and isn't stock firmware.
