hux2000
May 24, 2021Guide
Any way to automatically export logs from router?
If I log on to my X4S R7800 router's web interface, I can go to Advanced -> Administration -> Logs and then click "Send Log". I also see that I can have it send the logs to an email address automatic...
antinode
May 24, 2021Guru
> [...] Is there a way to make it send the logs automatically to syslog
> server? [...]
If that option is not offered, then I'd guess not. Around here
(D7000[v1], V1.0.1.78_1.0.1), the ADVANCED > Administration > Logs
options include (below the "Include in Log" options):
Syslog
(o) Disable
( ) Broadcast on LAN
( ) Send to this Syslog server IP address [_._._._]
So, apparently, they once knew how to do it.
> [...] Or save the logs as a text file?
Get your e-mail software to save those ADVANCED > Security > E-mail
"Send logs according to this schedule" e-mail messages?
