Zhoth
Mar 20, 2021Aspirant
Anybody try the new R7000 Firmware Version 1.0.11.116?
Hi guys, have you tried the last firmware 1.0.11.116 with the R7000? How does it work? Now I'm using .42, is it safe to upgrade or there are the same old issues? Thanks for your help!
Mar 20, 2021Guru - Experienced User
I don't have one but I've seen failry positive results on the forums.
I would make a backup of your current configuration (in case it doesn't work well for you) and try the update.
Not out anything to try if you've got a backup you can restore.
