mikeebee
Apr 18, 2021Aspirant
Anyone find stable R7300 firmware config after 1.0.0.68?
I am unable to find a stable firmware upgrade beyond 1.0.0.68 for the Nighthawk R7300 router. I've upgraded it each time, the latest try to 1.0.0.74_1.0.29 and have been met with unstable connection...
DarrenM
Apr 28, 2021Sr. NETGEAR Moderator
Have you tested the connection on the modem to see if it is stable?
DarrenM
- mikeebeeApr 28, 2021Aspirant
Not sure what you mean by this, as the router is very stable on .68, it's only the versions after this.
- DarrenMApr 28, 2021Sr. NETGEAR Moderator
Sorry didn't catch that the first time I read that. So the newer firmware has slower speeds on both wifi and hardline? also, are you having any wifi disconnect?
