mikeebee
Apr 18, 2021Aspirant
Anyone find stable R7300 firmware config after 1.0.0.68?
I am unable to find a stable firmware upgrade beyond 1.0.0.68 for the Nighthawk R7300 router. I've upgraded it each time, the latest try to 1.0.0.74_1.0.29 and have been met with unstable connection...
DarrenM
Apr 28, 2021Sr. NETGEAR Moderator
Have you tested the connection on the modem to see if it is stable?
DarrenM
mikeebee
Apr 28, 2021Aspirant
Not sure what you mean by this, as the router is very stable on .68, it's only the versions after this.
- DarrenMApr 28, 2021Sr. NETGEAR Moderator
Sorry didn't catch that the first time I read that. So the newer firmware has slower speeds on both wifi and hardline? also, are you having any wifi disconnect?
