agudteach
Aug 12, 2021Aspirant
Anywhere Access on R7000 - only 2.4G devices showing.
AA software to remote access R7000 as I'm currently NOMAD. Only 2.4Ghz devices show up and only 11 when I have 13 attached. How do I enable to see the 5Ghz devices? TIA
DexterJB
Aug 25, 2021NETGEAR Moderator
Hi agudteach, are you still encountering this issue?
- agudteachFeb 01, 2022Aspirant
Yes, still having problem with only 2.4 showing up and not all devices attached show.
Please advise.- michaelkenwardFeb 02, 2022Guru - Experienced User
Wow, you put up with that for more than four months before coming back?
You might get more help if you said more about your network. We don't even know what firmware is on your R7000.
You could also try a more detailed explanation of the problem. Brevity is great, but not at the expense of useful information and understanding.
As this is about using an app to work with Anywhere Access, you could see if anyone can help in the apps zone.
Nighthawk App - NETGEAR Communities
- agudteachFeb 02, 2022Aspirant
Yes, 4 months..... just got the notification that someone had answered my original post and oh - relocating from one country back to the US and just setting the router back up. But I appreciate your ping.
I posted here as I scoured the communities and didnt' find the answer.
I have R7000 with fmware is v.1.0.11.0.301Attached are the two screenshots. I can ONLY see 2.4GHZ and only see 4 devices when there are more attached. I am not able to toggle to 5GHZ.
