gavinbecker
Oct 28, 2020Initiate
Anywhere Access
I can't seem to find the option to turn on anywhere access anywhere in my nighthawk on my iphone. Any help is gretaly apprecieted. Every forum I've checker has said the same thing and my app is not d...
- Oct 28, 2020
By far not every Netgear router does support Anywhere Access. Look on How do I enable or disable Anywhere Access on my router using the Nighthawk app? for the models listed under "This article applies to:". Features not available on the router accessed by the Nightawk App will be invisible.
schumaku
Oct 28, 2020Guru - Experienced User
gavinbecker
Oct 29, 2020Initiate
ahhh looks like my router does not support it, thank you for the help.
