Leboa-Sako's avatar
Leboa-Sako
AP Mode Internet Connection and LED Query
Hello to you,   So for the last few days I have tried connecting the R7800 to the internet in Router Mode, but the router will not connect.   I use an ADSL modem, which the R7800 plugs into via t...
  • michaelkenward's avatar
    michaelkenward
    Nov 30, 2020
    Leboa-Sako wrote:
    Could someone confirm if the Internet LED on the R7800 (AP mode) should be flashing white or should it be a steady illumination (solid white) when connected to the internet?
    Solid white.
    The manual is good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    See the section Troubleshoot With the LEDs.
    You may have done this already, but I can't tell from your message.
