ErricoV's avatar
ErricoV
Tutor
Sep 14, 2021
app nighthawk continua ad interrompersi
buongiorno , app nightawk una volta installata si chiude da sola all'avvio, oppure riesce ad entrare , ma dopo qualche secondo si chiude automaticamente. una idea,,, grazie
    • ErricoV's avatar
      ErricoV
      Tutor
      hello, once installed nightawk app closes by itself at startup, or manages to enter, but after a few seconds it closes automatically. an idea ,,, thanks
      • FURRYe38's avatar
        Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App and know how to work it better than those of us who follow this "general router" forum. Might be more likely to find someone who has a solution if the question is posted there:
        https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
        Good Luck.
