Antonio1973
Feb 10, 2022Initiate
App Nighthawk Speed test
hi, wanted to know if it happens to you too that the Nighthawk app detects much higher wifi speed measurements than other wifi speed tests? Precisely on the Nighthawk app I reach 820/800 mb, while on ...
Feb 10, 2022Guru - Experienced User
Depending up on yoru ISP speeds, router, modem and what you having the app in stalled on will impact how the app detects and reports speeds. If your using a wireless device that doesn't have good support for wifi conenction rates, then the app may report lower results. Devices with higher speed support or AX modes, you should see nigher speeds being reported by the app.
Netgear has set up a community forum specifically for the Nighthawk App product. Most of the people who watch that forum are more likely to have experience with Nighthawk App:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Thank you.
