JNGR2018
Dec 12, 2020Tutor
App vs. Browser
Greetings, This FAQ link: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Top-NETGEAR-Support-FAQs-Router-Login-Firmware-amp-More/m-p/1881104 Says, "We highly recommend you use...
michaelkenward
Dec 13, 2020Guru - Experienced User
JNGR2018 wrote:
This FAQ link:
Says,
"We highly recommend you use the NETGEAR Nighthawk or Orbi app to access and monitor your router."
Can anyone explain to me why the apps are "highly recommended" as opposed to just accessing my router via a web browser, as I always have?
Probably because Netgear wants to dumb down things to the lowest common denominator.
Anyone with the tiniest bit of technical competence would warn against using a wifi based system that has limited features and is more liable to fall over than a wired link into a device.
- JNGR2018Dec 16, 2020Tutor
Thanks! That helps a lot.
